I registerd free account K6 cloud.
After running tests, going to the Analysis tab > Add new Chart, I did not see Utilization CPU & Utilization Memory.
Are they available for a free account?
Thanks,
Thanks,
Hi @thanhmp !
They should be available for free accounts too!
Could you please try to use this “Configure” button:
Let me know if that helps!
Cheers!
Hi @olegbespalov
I config thresholds like this
Okay, so you’re trying to config them as the thresholds that might be a bug ![]()
I’ll return after the investigations.
@olegbespalov
The issue has been fixed OK. Thanks
I can run test with config Presholds above.
But when I go to Analysis (Compare metrics) > Add New Chart, I did not see the list of metrics to add.
Below is the dialog to Add new chart.
@olegbespalov
'Add new chart" should be like this on Youtube?
Hi @thanhmp
I guess the youtube video has an outdated UI ![]()
Here is some documentation with the actual UI: Compare metrics
But TL;DR, you should click on the second dropdown where you have selected “VUs” and choose the other metric.
Cheers!
