Currently I’ve tried to use grafana notification using LINE.
DataBase,which I use is MySQL, and from that polls successfully.
And when I tested LINE notification, it woks well.
But the problem is, that the notification state had been already alert but sent nothing.
I think the reason is time setting at query, so at the test rule, I can see the data section ‘null’.
I attach couple of images, and I would be grateful if you answering my question.
Thanks
Moonjong Shin
