Thanks for the nudge!
Cluster is nothing special really, just a regular EKS cluster with Istio.
I exec’d into the Alloy pod, installed curl, and tried to reach the kube_api_server. Outputs are below. Since I get a 401 Unauthorized response (didn’t provide any auth), I think the connectivity/route is fine?
# printenv | grep KUBERNETES_
KUBERNETES_SERVICE_PORT_HTTPS=443
KUBERNETES_SERVICE_PORT=443
KUBERNETES_PORT_443_TCP=tcp://172.20.0.1:443
KUBERNETES_PORT_443_TCP_PROTO=tcp
KUBERNETES_PORT_443_TCP_ADDR=172.20.0.1
KUBERNETES_SERVICE_HOST=172.20.0.1
KUBERNETES_PORT=tcp://172.20.0.1:443
KUBERNETES_PORT_443_TCP_PORT=443
# curl -v https://172.20.0.1:443 -k
* Trying 172.20.0.1:443...
* Connected to 172.20.0.1 (172.20.0.1) port 443
* ALPN: curl offers h2,http/1.1
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
* TLSv1.3 (IN), TLS handshake, Request CERT (13):
* TLSv1.3 (IN), TLS handshake, Certificate (11):
* TLSv1.3 (IN), TLS handshake, CERT verify (15):
* TLSv1.3 (IN), TLS handshake, Finished (20):
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.3 (OUT), TLS handshake, Certificate (11):
* TLSv1.3 (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / TLS_AES_128_GCM_SHA256 / X25519 / RSASSA-PSS
* ALPN: server accepted h2
* Server certificate:
* subject: CN=kube-apiserver
* start date: Jun 09 03:00:39 2025 GMT
* expire date: Jun 09 03:05:39 2026 GMT
* issuer: CN=kubernetes
* SSL certificate verify result: unable to get local issuer certificate (20), continuing anyway.
* Certificate level 0: Public key type RSA (2048/112 Bits/secBits), signed using sha256WithRSAEncryption
* using HTTP/2
* [HTTP/2] [1] OPENED stream for https://172.20.0.1:443/
* [HTTP/2] [1] [:method: GET]
* [HTTP/2] [1] [:scheme: https]
* [HTTP/2] [1] [:authority: 172.20.0.1]
* [HTTP/2] [1] [:path: /]
* [HTTP/2] [1] [user-agent: curl/8.5.0]
* [HTTP/2] [1] [accept: */*]
> GET / HTTP/2
> Host: 172.20.0.1
> User-Agent: curl/8.5.0
> Accept: */*
* TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
* received GOAWAY, error=0, last_stream=1
< HTTP/2 401
< audit-id: a3e4412b-0c1f-4a36-b7d7-4f981b136e83
< cache-control: no-cache, private
< content-type: application/json
< content-length: 157
< date: Tue, 10 Jun 2025 21:46:11 GMT
"kind": "Status",
"apiVersion": "v1",
"metadata": {},
"status": "Failure",
"message": "Unauthorized",
"reason": "Unauthorized",
"code": 401
* Closing connection
* TLSv1.3 (OUT), TLS alert, close notify (256):
Edit: By using the appropriate cert and token, I get a 200 OK response.
# curl --cacert /var/run/secrets/kubernetes.io/serviceaccount/ca.crt --header "Authorization: Bearer $(cat /var/run/secrets/ubernetes.io/serviceaccount/token)" -X GET https://172.20.0.1:443/api
"kind": "APIVersions",
"versions": [
"v1"
"serverAddressByClientCIDRs": [
"clientCIDR": "0.0.0.0/0",
"serverAddress": "ip-<ip>.<region>.compute.internal:443"
