Alloy stage.template not working
I’m trying to use stage.template stage to combine multiple fields into output. However whatever i configure template with, nothing works and output is always returned empty. I spent countless hours trying to get the stage working, but fruitlessly. That is very weird because when i leave template out completely, the labels level and output message will get extracted to log lines succesfully.
          stage.match {
            selector = "{app=~\"(am.*)\"} != \"error.stack\""
            stage.json {
              expressions = {
                message = "message",
                level = "level",
            stage.labels {
              values = {
                level = "level",
            stage.template {
              source   = "fmt"
              template = "{{ .level }} {{ .message }}"
            stage.output {
              source = "fmt"
I am using latest Alloy v1.8.3
Don’t see anything obviously wrong. Do you have a couple of samples of your logs?
Following JSON lines:
{"service":"am-booter","environment":"beta","@timestamp":"2025-04-23T06:08:34.57440483Z","@version":"1.0.0","message":"HikariPool-1 - Shutdown initiated...","logger_name":"com.zaxxer.hikari.HikariDataSource","thread_name":"SpringApplicationShutdownHook","level":"INFO"}
{"service":"am-booter-invest","environment":"alpha","@timestamp":"2025-04-23T06:02:27.367011582Z","@version":"1.0.0","message":"A message has been sent to AMQP exchange=input-exchange.","logger_name":"c.c.a.c.a.amqp.AmqpClient$Companion","thread_name":"http-nio-8080-exec-7","level":"INFO","req.requestURI":"/run","req.xForwardedFor":"103.202.232.124","request.user_id":"22f955@us-west-1_0vFh","req.method":"POST","req.remoteHost":"14.139.00.00","req.requestURL":"https://alpha-booter-EKS-NLB-3buy998bad2.elb.us-east-1.amazonaws.com/run"}
After implementing stage.template, output is: “” for both of them.
I suspect your match here is not working:
stage.match {
I tested your config and it seems to be working. I omitted the match part because I am not sure what you are matching for.
Test.log:
config:
loki.process "process_logs" {
  forward_to = [<FORWARD>]
    stage.json {
       expressions = {
         level = "level",
     stage.labels {
       values = {
       level = "level",
   stage.template {
     source   = "fmt"
   stage.output {
     source = "fmt"
Perhaps share your entire alloy configuration?
Thank you for the reply. I still face same problems with the template stage, when leaving out the matching block entirely, resulting in empty output
        logging {
          level = "error"
          format = "logfmt"
        // LOKI WRITE ENDPOINT
        loki.write "loki" {
          endpoint {
            url = "https://loki.engineering/loki/api/v1/push"
        // LOKI LOGS
        discovery.kubernetes "pod" {
          role = "pod"
        discovery.relabel "pod_logs" {
          targets = discovery.kubernetes.pod.targets
          rule {
            source_labels = ["__meta_kubernetes_namespace"]
            action = "replace"
            target_label = "namespace"
          rule {
            source_labels = ["__meta_kubernetes_pod_name"]
            action = "replace"
            target_label = "pod"
          rule {
            source_labels = ["__meta_kubernetes_pod_container_name"]
            action = "replace"
            target_label = "container"
          rule {
            source_labels = ["__meta_kubernetes_pod_label_app_kubernetes_io_name"]
            action = "replace"
            target_label = "app"
          rule {
            source_labels = ["__meta_kubernetes_pod_uid", "__meta_kubernetes_pod_container_name"]
            action = "replace"
            target_label = "__path__"
            separator = "/"
            replacement = "/var/log/pods/*$1/*.log"
        loki.source.kubernetes "pod_logs" {
          targets    = discovery.relabel.pod_logs.output
          forward_to = [loki.process.pod_logs.receiver]
        loki.process "pod_logs" {
          stage.static_labels {
            values = {
              cluster = "platform-engineering",
          stage.json {
            expressions = {
              level = "level",
          stage.labels {
            values = {
              level = "level",
          stage.template {
            source   = "fmt"
          stage.output {
            source = "fmt"
          forward_to = [loki.write.loki.receiver]
Can you take out stage.output and see what the result looks like, please?
After removal, no logs appear at all
Then that means you have something somewhere filtering out or dropping all the logs.
Can you share your entire Alloy configuration, please?
Configuration is the pretty much the same as before. Am i the only one, who doesn’t get stage.template to work ? Again, if i leave out the template and set output source to message, it’s working as expected:
     logging {
          level = "error"
          format = "logfmt"
        loki.write "loki" {
          endpoint {
        // LOKI LOGS
          role = "pod"
          rule {
            action = "replace"
          rule {
            action = "replace"
          rule {
            action = "replace"
          rule {
            action = "replace"
          rule {
            action = "replace"
            separator = "/"
            values = {
          stage.json {
            expressions = {
          stage.template {
            source   = "fmt"
            template = "message: {{ .message }}"
          stage.output {
            source = "fmt"
with this configuration log output is always message:
@henrikj was your alloy config in a helm values file per chance?
/If/ it is, rather than a template like :
“[{{.thread}}] {{.content}}”
I found I had to write something like this, I hope someone on the internet can tell me how to create it in a less insane way, but at least this works:
“[{{”{{“}}.thread{{”}}“}}] {{”{{“}}.content{{”}}“}}”
