Given the following logline:
{"log":"2025-03-11T09:38:41.700139662Z stdout F {\"appName\":\"test",\"appVersion\":\"1.23.2\",\"environment\":\"dev\",\"level\":\"info\",\"message\":\"readiness probe succeeded\",\"timestamp\":\"2025-03-11 09:38:41\"}","environment":"dev","cluster_name":"eks-dev"}
I am trying to parse everything and output only the message inside the log field.
stage.json {
expressions = { "log" = "log", "environment" = "environment", "cluster_name" = "cluster_name" }
stage.labels {
values = { "environment" = "environment", "cluster_name" = "cluster_name" }
stage.output {
source = "log"
stage.cri {}
I thought the above configuration would work but the CRI stage fails with the logs:
ts=2025-03-12T07:36:59.694075856Z level=debug msg="extracted data did not contain output source" component_path=/ component_id=loki.process.logs_process ts=2025-03-12T07:36:59.694127731Z level=debug msg="extracted data did not contain a timestamp" component_path=/ component_id=loki.process.logs_process
I feel like I am making a simple mistake but if anyone has any idea what is wrong I would really appreciate it.
