Trying to install Grafana Alloy
Install Grafana Alloy on macOS | Grafana Alloy documentation -
Trying to integrate Jenkins with Grafana using this link:
Jenkins integration | Grafana Cloud documentation -
What happened?
Alloy gets installed successfully -
says already downloaded. is alloy already running?
how about a manual install, download the tar file etc
Thanks, let me try it.
I have extracted the tar file contents. How do I install Alloy now, Thanks.
It is okay. I reinstalled Homebrew and now it is able to install. Thanks.
what have you tried and what are you blocked on
The issue has been resolved. We reinstalled Homebrew and were able to complete the installation. Thanks.
