greetings @tonyswumac
any idea what this color key:value is?
loki.source.file "example" {
// Collect logs from the default listen address.
targets = [
{__path__ = "/tmp/foo.txt", "color" = "pink"},
{__path__ = "/tmp/bar.txt", "color" = "blue"},
{__path__ = "/tmp/baz.txt", "color" = "grey"},
forward_to = [loki.write.default.receiver]
I think that’s just to say that you can supply additional labels along with __path__
. Maybe the documentation can be made clear by changing it to this?
targets = [
{__path__ = "/tmp/foo.txt", "additional_label1" = "additional_label_value1"},
{__path__ = "/tmp/bar.txt", "additional_label2" = "additional_label_value2"}},
{__path__ = "/tmp/baz.txt", "extr_label3" = "additional_label_value3"}},
