Allow unsupported browser
Hi Everyone,
    Grafana v9.0.2, Ubuntu 20.04.4 LTS
    View dashboards on an old Android v4.4.2 tablet
    Using Chrome v81 or the inbuilt browser to view a dashboard.
  • What happened?
    Get the following error:
If you're seeing this Grafana has failed to load its application files
1. This could be caused by your reverse proxy settings.
2. If you host grafana under subpath make sure your grafana.ini root_url setting includes subpath. If not using a reverse proxy make sure to set serve_from_sub_path to true.
3. If you have a local dev build make sure you build frontend using: yarn start, yarn start:hot, or yarn build
4. Sometimes restarting grafana-server can help
5. Check if you are using a non-supported browser. For more information, refer to the list of supported browsers.
I realise that the tablet is very out of date, so old that it is no longer accepting updates to the latest version of Chrome.
Unfortunately I can’t afford to upgrade it yet. Is there a way to enable access for unsupported browsers to Grafana without downgrading Grafana?
Thanks
I don’t think so, sorry!
You could try installing an older version of grafana instead.
Can you view any modern grafana dashboard?
https://play.grafana.org
That’s a shame.
Is there a way to check what version I would need to return to, to be able to get compatibility back?
UP,
is anyone know the latest version compatible with android4.4’s browser of grafana ?
Chrome version : 81.0 max
