What do I do to ensure that my labels and fields in the query editor are aligned nicely?
As seen in the image (only an example for illustration), the “Druid” datasource plugin has many dips/rises when moving from labels to inputs etc, whereas the simplejson plugin has good alignment.
It would be very helpful if someone could advice on how to set the alignment for druid plugin (or any other example). Thanks!
