Alert tab does not appear - Sqlite to Grafana
I have an issue with Grafana, Alert tab does not appear for me.
Do you have any ideas ?
Maybe its the Sqlite plugin that I use.
Thanks !
I think that is not supported for SQLite currently :
Alert execution
Alert rules are evaluated in the Grafana backend in a scheduler and query execution engine that is part of core Grafana. Only some data sources are supported right now. They include Graphite , Prometheus , InfluxDB , Elasticsearch , Google Cloud Monitoring , Cloudwatch , Azure Monitor , MySQL , PostgreSQL , MSSQL , OpenTSDB , Oracle , and Azure Data Explorer .
Link :
Hope it helps.
Good Luck
what version of the grafana are you using at the moment ?
my grafana version is v7.4.2
is it possible to downgrade?
it I can handle alerts yes :slight_smile:
ok then the issue is resolved
What do you mean ? What kind of version should I use ?
but you said with another version you can handle alerts . then you take this version
No sorry, Its my first time with grafana, I never tried an other version than v7.4.2. What I meant is that if you know of an older version that works with alerts SQLITE , I can downgrade my version
yes! try out older version, for sure
