Alert payload IRM forwards to Grafana Assistant is not being parsed correctly
We’re using Grafana IRM to send alerts from our cluster to Grafana Cloud, and as part of this setup, we configured an Outgoing Webhook in Grafana IRM Integration to automatically trigger a new investigation in the Grafana Assistant Investigation API upon alert group creation.
Although we are sending a raw JSON payload with an alerts array, The Grafana assistant API responds with description “No alerts present.”
Outgoing webhook Details:
Source: Grafana OnCall Event Body (raw)
Destination API: https://xxx/api/plugins/grafana-assistant-app/resources/api/v1/investigations/from-irm
Trigger Type: Alert Group Created.
Response:
    "$schema": https://assistant-prod-us-east-0.grafana.net/schemas/ResponseBodyInvestigationResponse.json,
    "status": "success",
    "data": {
        "id": "c874641e-6487-4db3-b73a-fcf6c7d4b927",
        "title": "\n  <Title> - Investigation Report",
        "description": "Investigation report for: No alerts present in the request.\n",
        "state": "pending",
        "chatId": "480cdf6a-96ad-437d-a741-21b45e54c8e4",
        "createdAt": "2025-10-31T12:36:32Z",
        "updatedAt": "2025-10-31T12:36:32Z",
        "confidence": 0,
        "source": {
            "type": "url",
            "value": https://<domain>//a/grafana-irm-app/alert-groups/IHZVS79PUSMTC
Can someone help me with a valid JSON structure (schema) the Assistant Investigation API expects in the request body.
