is it possible to set up an alert rule for a significant change in a time series in a given time interval? e.g. weight increase in the last 10 minutes above 2kg.
Thanks for your answers
if your metric query tracks a derivative (rate of change) then you can set a threshold based on that.
Sorry to revive such an old thread.
I use thresholds on a derivative metric for rates of change on important KPIs, but there is no way to receive alerts when those thresholds are broken - correct?
I tried to set an alert on a derivative value, but the test shows that no data is being sent to the alert.
Is there a workaround that allows for alerts to be sent when certain derivative values are met?
Thank you
