8.1.1 -
Showing the value in the alert message -
Using a template as follows: Water tank distance at {{ .Value }} -
What happened?
Output is: Water tank distance at [ metric=‘mqtt_consumer’ labels={host=REDACTED, topic=REDACTED} value=23.877 ] -
I want the message to read: Water tank distance at 23.877 -
No -
Message templating | Grafana documentation
Template data | Grafana documentation
Have you tried without .(dot)
Water tank distance at {{ Value }}
Could also be case sensitive. I see you have value with small v not capital.
/ Carsten
It turns out that I cannot do this with a “Classic Condition” In order for it to work I needed to use a Reduce expression to reduce the sample set to a single value then use a Math expression to give a value of 0 or 1.
I can then use something like {{ $values.B.Value }} in the alert summary
