Alert list doesn't work right
Hi I’m using alert list in dashboard for monitor the error and no data issue but it have something work not right with no data.
My expect is if I tick to no data in alert list it should be show all no data alert.
Version Grafana: 9.3.2
This is screenshot when i tick to no data and not tick to normal
This is screenshot when i tick to no data and normal
My setting for no data
Screenshot from 2023-01-10 13-56-05
This is definitely a bug, or rather a peculiar inconsistency in how we handle alert rules states and alert instance states.
I’ve taken the liberty to investigate a bit further and have arrived at a PR that will correctly filter rules / instances when either NoData or Error states are being applied to the alert list panel.
Thanks for your support
