Hallo All,
i deleted a Alert Folder , but i still receiving Firing notification.
i’m using Grafana V.9.3; InfluxDB
where can i find the deleted folder?
how can i find the deledet folder?
thank you
Hallo All,
thank you
Hi @kabs , deleting a folder that has an alert associated with it fails with a yellow warning and it should not delete the alerts nor the folder.
Could you please share the detailed steps for reproducing your issue? thank you!
how did you delete this folder? from the ui?
Could you please reproduce steps and share screenshots , in particular when you are deleting the folder that contains alert rules? Because, as I said before, if the folder that has an alert associated with it fails with a yellow warning and it should not delete the alerts nor the folder.
Hi @soniaaguilar,
It’s been awhile since I did the cleanup but the alarm I deleted via UI would not be in an alerting state as it relates to disk space and only now is the limit being hit.
So it’s pretty much:
Note I cannot find the alarm via the UI, hitting api/v1/provisioning/alert-rules/IkZWM1M4z does give back the alert configuration, sending a DELETE does indeed remove it.
