When re-editing a Contact point - if you want to edit an additionally added contact point integration it doesn’t appear possible - it only loads the first integration
In my example I have an entry for myself that has x2 contact point integrations - the first is email, the second is Microsoft Teams.
If I try and edit the second one it is not possible
If I use the pull down option over Integration and change it to Microsoft Teams the URL has been blanked out
I’m using Grafana Cloud
For what it’s worth the Microsoft Teams URL is present and correct in the YAML if I export the entire contact point, so it’s a UI bug potentially
Thanks
