Alert configuration with file
HI
I would like to configure the alert system using file all the documentation i found his for to do it manualy with the interface.
Someone have an example or can point me the correct documentation ?
Thanks
Herve
welcome to the :grafana: forum, @hervedang
Can you confirm: are you using the new Unified Alerting platform or the legacy platform?
@anon70503803 thanks for the welcom
Yes I used the new unified alert platform (but i was using the legacy before for my alert system) but since a crash of our influxdb 1.8 db we try to upgrade it in the same time as grafana to use newer version
While waiting for an answer i continue with configure the notification channel manualy but as the alert system change my old alert who where added whith my generated dashboard is not here anymore and i did not find yet how i can generate with the dashboard can you help me ?
thanks
I would like to know more about the original question: Is it possible to set up the alerting through a configuration file? I am looking at the Unified Alerting platform as well. I saw that on the admin tab there is a default Alerting configuration. Unfortunately it only contains options for notification policies and contact roles. Can I manage all the alerting configuration (alert rules as well) from here?
On the legacy alert configuration we have set up the notification channels according to this documentation: Provisioning | Grafana Labs
and the alerts were a part of the dashboard configuration which is also possible to backup as a JSON file.
I am wondering how can I reach the same with the new Unified Alerting platform?
Many Thanks,
Edit
i have same problem… with grafana 8.4.4
Any response please? Probably the same problem on our side.
Is there any way how to generate alert rule to JSON/Yaml?
Now I have to modify the provisioning file manually and it is pretty annoying.
Here - Grafana alert I see
2. Use the Alerting provisioning API to extract the alert rule.
There are only endpoints for reloading alerts rules.
How can I extract them?
Thanks
Jan
