I need help because i have one metric that should be alarmed but its not firing.
The A query its on 90% and the threshold its 85%
bject
firing:false
state:“”
conditionEvals:“[[false OR false] OR false] = false”
timeMs:“84.575ms”
logs:Array[9]
0:Object
message:“Condition[0]: Query”
data:Object
queries:Array[1]
0:Object
to:1570208652168
1:Object
message:“Condition[0]: Query Result”
data:Object
series:Array[0]
2:Object
message:“Condition: Eval: false, Query Returned No Series (reduced to null/no value)”
data:null
3:Object
message:“Condition[1]: Query”
data:Object
queries:Array[1]
to:1570208652195
4:Object
message:“Condition[1]: Query Result”
data:Object
series:Array[0]
5:Object
data:null
6:Object
message:“Condition[2]: Query”
data:Object
queries:Array[1]
0:Object
to:1570208652226
7:Object
message:“Condition[2]: Query Result”
data:Object
8:Object
data:null
Hello, any one can give me a hand?
Thanks
devino
October 9, 2019, 1:53pm
3
Hello, as I can see query result return no data. Can you show me the A,B and C query? Also I can see you try to evaluate every 10minutes for 0minutes - that could be the problem also.
Hello Devino,
Its Strange, because the query has Data; the graph its ok, but the query says “no data”
bject
xhrStatus:“complete”
request:Object
method:“GET”
url:“api/datasources/proxy/1/query”
params:Object
db:“dbtelegraf”
q:“SELECT mean(“used_percent”) FROM “autogen”.“disk” WHERE (“host” = ‘zmbox02.xxx.com.ar’ AND “path” = ‘/opt’) AND time >= now() - 2d GROUP BY time(5m) fill(null);SELECT mean(“used_percent”) FROM “autogen”.“disk” WHERE (“host” = ‘zmbox02.xxx.com.ar’ AND “path” = ‘/opt/zimbra/backup’) AND time >= now() - 2d GROUP BY time(5m) fill(null);SELECT mean(“used_percent”) FROM “autogen”.“disk” WHERE (“host” = ‘zmbox02.xxx.com.ar’ AND “path” = ‘/opt/zimbra/store2’) AND time >= now() - 2d GROUP BY time(5m) fill(null)”
epoch:“ms”
data:null
precision:“ms”
response:Object
results:Array[3]
0:Object
statement_id:0
series:Array[1]
0:Object
columns:Array[2]
0:“time”
1:“mean”
values:Array[577]
0:Array[1570538700000,91.35666006917897]
1:Array[1570539000000,91.35947757501255]
2:Array[1570539300000,91.3637457447279]
3:Array[1570539600000,91.3687945380415]
4:Array[1570539900000,91.37564642051493]
5:Array[1570540200000,91.37897495709902]
6:Array[1570540500000,91.37849375320678]
7:Array[1570540800000,91.38047458055907]
8:Array[1570541100000,91.38390936533625]
9:Array[1570541400000,91.3882696087976]
10:Array[1570541700000,91.39059481792759]
11:Array[1570542000000,91.39402362440322]
12:Array[1570542300000,91.39778753542429]
13:Array[1570542600000,91.40091933578277]
14:Array[1570542900000,91.40683465418996]
15:Array[1570543200000,91.4114178960224]
16:Array[1570543500000,91.4160875116522]
17:Array[1570543800000,91.42306642899368]
18:Array[1570544100000,91.42492767953935]
19:Array[1570544400000,91.42799879717361]
20:Array[1570544700000,91.43229951621797]
21:Array[1570545000000,91.43662289318692]
22:Array[1570545300000,91.4423245569007]
23:Array[1570545600000,91.44695665056194]
24:Array[1570545900000,91.45212523438535]
25:Array[1570546200000,91.4574037891472]
26:Array[1570546500000,91.45952838845693]
