After upgrade of Grafana service stopped running
  • grafana-9.2.10-20.el8_10.x86_64
  • Running on RHEL
  • Starting the grafana service
  • Installing grafana and configuring Shared DB on mysql
  • What happened?
  • Service Startup failing.
  • Service to be up and running.
  • logger=settings t=2024-11-15T10:46:48.327361762+13:00 level=info msg=“Config overridden from Environment variable” var=“GF_DATABASE_NAME=grafana”
    logger=settings t=2024-11-15T10:46:48.327377316+13:00 level=info msg=“Config overridden from Environment variable” var=“GF_DATABASE_USER=admin”
    logger=settings t=2024-11-15T10:46:48.327392757+13:00 level=info msg=“Config overridden from Environment variable” var=“GF_DATABASE_PASSWORD="
    logger=settings t=2024-11-15T10:46:48.327414798+13:00 level=info msg=“Config overridden from Environment variable” var="GF_SECURITY_ADMIN_PASSWORD=
    logger=settings t=2024-11-15T10:46:48.327430569+13:00 level=info msg=“Path Home” path=/usr/share/grafana
    logger=settings t=2024-11-15T10:46:48.327448103+13:00 level=info msg=“Path Data” path=/var/lib/grafana
    logger=settings t=2024-11-15T10:46:48.327462626+13:00 level=info msg=“Path Logs” path=/var/log/grafana
    logger=settings t=2024-11-15T10:46:48.32747715+13:00 level=info msg=“Path Plugins” path=/var/lib/grafana/plugins
    logger=settings t=2024-11-15T10:46:48.327492595+13:00 level=info msg=“Path Provisioning” path=/etc/grafana/provisioning
    logger=settings t=2024-11-15T10:46:48.327508815+13:00 level=info msg=“App mode production”
    logger=sqlstore t=2024-11-15T10:46:48.327601923+13:00 level=info msg=“Connecting to DB” dbtype=mysql
    logger=migrator t=2024-11-15T10:46:48.330274975+13:00 level=error msg=“alert migration failure: could not get migration log” error=“failed to check table existence: dial tcp 10.86.84.216:3306: connect: permission denied”
  • Yes
  • Configure Grafana | Grafana documentation
