Additional hover information on Time Series Panel with PostgreSQL
    Grafana 10.1.0 on Linux
    In a Time Series Panel, add contextual information for each point in the hover box.
Each point concerns a “unit” produced by a factory.
The value I’m plotting is a quality score for each unit.
Each unit also has contextual information like the factory id and production line id.
I’d like to be able to have this information in the hover box when mouse hovering over a point.
    Adding the factory id and production line id as fields in my query.
  • What happened?
    Fields were used to display the points as different time series, one per factory id and production line id couple.
    Have a way to differentiate between fields used to split time series (like what happened) and fields to be added as hover box information.
    No.
    No.
