9.0.0 -
Add a annotation with a new tag -
clcik in the graph, add annotation, type description then click in the tags field and try to type something. - What happened?
Immidiatly when beginning typing in the tags box it failes with error: e.toLowerCase is not a function - What did you expect to happen?
To add a new or excisting tag - Can you copy/paste the configuration(s) that you are having problems with?
No - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
In the UI : e.toLowerCase is not a function - Did you follow any online instructions? If so, what is the URL?
No
do you think you could try and replicate this on our public sandbox, https://play.grafana.org? ![]()
I wasn’t able to reproduce this issue there, which is running 9.0.2`
Also seen same behavior on 9.0.1. Works fine on 9.0.2 (Sandbox)
I just upgraded to the last version 9.1.1. and the problem is gone.
Thanks for the advice
