Hi All,
I am trying add postgres datasource using ansible and task looks like below.
- name: Add PostgreSQL data source
uri:
url: “{{ grafana_url }}/api/datasources”
method: POST
body_format: json
body:
type: ‘postgres’
url: ‘localhost:5432’
access: ‘proxy’
database: ‘your_database’
user: ‘your_username’
secureJsonData:
password: ‘your_password’
isDefault: true
headers:
Authorization: “Bearer {{ token }}”
Content-Type: “application/json”
return_content: yes
status_code: 200
Eventhough the datasource getting added but type shows undefined, when i open settings, i can see only Delete option. Can someone help me to identify what could be the issue and i am using grafana 10.4 OSS.
I think type should be PostgreSQL?
I tried postgresql as well, still same error. Anything mistake I am doing in playbook above and by the way I am using poatgres 10.4.0 version.
I went with below approach and it worked and also i went with grafana version to 10.0.0. since community.grafana.grafana_datasource tested till 10.2.2 i think.
- name: Create postgres datasource
community.grafana.grafana_datasource:
grafana_url: “{{ grafana_url }}”
grafana_user: “{{ grafana_admin_user }}”
grafana_password: “{{ grafana_admin_password }}”
#org_id: “1”
ds_type: “postgres”
ds_url: “{{ postgres_url }}”
database: “{{ db_name }}”
user: “{{ db_owner }}”
sslmode: “disable”
additional_json_data:
postgresVersion: 15
timescaledb: false
additional_secure_json_data:
password: “{{ db_password }}”
