Grafana Version 9.4.3 -
I am trying to configure a Notification template via the grafana hel chart. -
How to pass notification template from values.yaml for Grafana Helm chart - Stack Overflow -
What happened?
I don’t see any notification template in grafana. -
I expect that the change invalues.yaml
adds a notification template in grafana. -
No -
