Grafana 9.3.2 -
I am trying to get notified according to my alert rules when things go bad, and with full info. - How are you trying to achieve it?
- I am using http_response telegraf input plugin to monitor some of my web applications, and I set alert rules based on the result_code of the http_response plugin parameter. In query A, I put influxdb query to return a value of result_code from the plugin, and in query B I used classic conditions to serve as alert condition.
- What happened?
- Until recent time when my web applications go down I got the alert notification in the following format:
**Firing**
Value: [ var='B0' metric='Value' labels={server=url_of_the_web_application} value=4 ]
Labels:
- alertname = 'alertname'
- grafana_folder = 'folder'
- type = system_status
Annotations:
- description = description
Source: http://grafana.staged-by-discourse.com/alerting/grafana/YkofxuR4z/view
Silence: http://grafana.staged-by-discourse.com/alerting/silence/new?alertmanager=grafana&matcher=alertname%3Dalertname&matcher=grafana_folder%3Dalertname&matcher=type%3Dsystem_status
As you can see above the value key got many details including the URL of the web application. But presently I am not getting those details instead am just getting this:
**Firing**
Value: B=4
Labels:
- alertname = alertname
- grafana_folder = foldername
Annotations:
I was expecting to get notified with details of the info just like before, I haven’t changed anything by my side, maybe grafana update would change that? - Can you copy/paste the configuration(s) that you are having problems with?
from(bucket: "system_stat")
|> filter(fn: (r) => r["_measurement"] == "http_response")
|> filter(fn: (r) => r["_field"] == "result_code")
|> filter(fn: (r) => r["host"] == "grafana")
|> filter(fn: (r) => r["method"] == "GET")
|> group(columns: ["server"])
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
|> yield(name: "last")
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Nope - Did you follow any online instructions? If so, what is the URL?
Nope
