hi everyone,
i am really having hard time to add extra jobs in promtail deployed with help of helm chart grafana/loki-stack.
i have tried to copy the values file from the helm chart
cp -p loki-stack/charts/promtail/values.yaml $OLDPWD/values_promtail_nginx_or.yaml
then added following conf to it:
- job_name: nginx
static_configs:
- targets:
- localhost
labels:
app: nginx
env: production
host: ruan-prod-nginx
__path__: /var/log/nginx/*.log
pipeline_stages:
- match:
selector: '{app="nginx"}'
stages:
- regex:
# logline example: 127.0.0.1 - - [21/Apr/2020:13:59:45 +0000] "GET /?foo=bar HTTP/1.1" 200 612 "http://example.com/lekkebot.html" "curl/7.58.0"
expression: '^(?P<host>[\w\.]+) - (?P<user>[^ ]*) \[(?P<timestamp>.*)\] "(?P<method>[^ ]*) (?P<request_url>[^ ]*) (?P<request_http_protocol>[^ ]*)" (?P<status>[\d]+) (?P<bytes_out>[\d]+) "(?P<http_referer>[^"]*)" "(?P<user_agent>[^"]*)"?'
- labels:
host:
method:
request_url:
status:
user_agent:
then tried to upgrade the helm chart:
helm upgrade loki grafana/loki-stack --set resources.requests.cpu=100m --set resources.requests.memory=256Mi -f values_promtail_nginx_or.yaml
then deleted my promtail pods
kubectl delete pods -l app.kubernetes.io/name=promtail so they get re-deployed using the new config from values_promtail_nginx_or.yaml file.
however when i go to my promtail pod, the promtail.yaml conf is still the original one which came with initial deployment of loki helm chart.
I’m seeking guidance on how to update the promtail.yaml configuration file to parse nginx logs. My goal is to break down these logs into multiple fields, which will enable me to construct Grafana dashboards based on the values of these fields. Any assistance with this process would be greatly appreciated.
THanks in advance
