Add logic to Grafana with promtheus data source
    7.5.2
    Show databases based on ENV selection, like select PROD and it will show the prod databases that are in a custom variable, using prometheus as data source.
    Using custom variables to write down the database names.
  • What happened?
    Can’t find a way or lack the experience to do what I need.
    Still trying to figure out if my approach is correct or is there a better approach.
    N/A
    Nope
first, if you are new to Grafana, upgrade immediately. 7.5.2 is too old.
second, check out this dashboard:
https://play.grafana.org/d/000000029/prometheus-demo-dashboard?orgId=1&refresh=5m
also: Here are the docs on template variables. And here is a list of good examples on play.grafana.org that use template variables. You can inspect each dashboard to see just how the variables are constructed.
