Ad hoc filters variable appended to stream label, not to the label filtering section
how the grafana ad hoc filters variable works?
I use data source loki,
the ad hoc filters variable generate the final expression is:
{service_name="agent-example-app", trace_id="705700ec6b2cd0edbf679859ee76bb25"} |= ``
but what I want is :
{service_name="agent-example-app"} |= `` | trace_id="705700ec6b2cd0edbf679859ee76bb25"
you can see from the image below, there is no data found, I inspected the query,
The query is the first query I posted above. There is no data because My trace_id is not a indexed label.
Let me give the answer by myself:
use this query: {ervice_name=“agent-example-app”}|=``| logfmt. The key point is put `logfmt`.
If you put the logfmt in the end of the query, then you do some filters, the trace_id=******** will be appended at the end of the query, not insert it in the stream filter.
