Grafana v10.1.5 (849c612fcb)
I’m setting up dashboard to let developers access Traefik logs (stored on Loki and queried with . I’m preparing some variables that they can use to filter data.
I can use regular expression defaulting to .*
to match any for some. However, I’ve some variables that are used as prefix or infix:
${prefix_variable}-.*
.*-${infix_variable}-.*
The wildcard don’t work as it still enforce the label/field contains the static characters (e.g. separator, static prefix)
I don’t see how to build (and if this possible) the log stream selector part with given constraints.
What happened?
N/A
Being able to query with optional variables/label selectors
N/A
N/A
No.
