Ad-hoc filter with wildcard
I would like to know if it’s possible to use wildcard in the ad-hoc filters (and how if it’s possible) ?
I tried this but it doesn’t work:
chrome_2017-10-10_17-54-32
Thanks.
No this is not currently possible
Thanks for your answer.
Do you think it will be in the roadmap in the future ?
But you can use operator =~ and then you can use your regex. I tried it and all fine
use the operator =~ and the field value should be s2a.*
