I am using InfluxDB 2.0 and flux language for writing the queries.
I am using Grafana-Cloud for visualizing the queries.
I am trying to create the ad-hoc filters but nothing comes in the ad-hoc filter.
It always shows no options found.
whole dashboard work file and I have used many template variables as well and everything works fine but the ad-hoc filter is not working at all.
Do Ad-hoc filters support InfluxDB 2.0? If yes, then what I am doing wrong so I am not getting any values.
I am facing a similar issue using the following setup:
Grafana Open Source version 10.0.1
InfluxDB version 2.7.1
Query Language: Flux
When using a variable of type adhoc filter on a dashboard, the dropdown list stays empty showing “No options found”. When looking at request at response I get the impression that InfluxQL is used instead of Flux. Might this cause problems and is there a way to change the behavior?
Your request is using InfluxQL instead of Flux. A Flux request for a varaible to display the values of the tag “EquipNumber” on a dashboard would look like this:
thanks for your quick reply. My understanding is that the request is generated automatically by Grafana when clicking “+” to use the ad hoc filter on the dashboard:
