I am developing a Grafana plugin in React/Typescript.
The data is being fetched from an SQL data source and formatted as Table.
I used to be able to access this data via my panel’s properties using
const { series } = this.props.data;
const myData = series[0].rows
Ever since today, Typescript tells me that series from the PanelData is of type DataFrame[]. And DataFrame does not possess an attribute called rows (logging series[0] to console clearly shows it having this attribute though).
The only type that does have an attribute called rows is TableData (which would make sense to use since I work with table data). But according to Typescript, series can not be of this type. Neither does PanelData contain anything else that could contain my data.
Am I missing something here? Or is this a recently introduced bug within the types?
How am I supposed to access my table data now?
Thanks in advance, regards,
Tim
[Edit:]
In version 6.3.2 of @grafana/data DataFrame used to have the attribute rows: any[][]. This seems to have be removed with 6.4.0.
