So I am trying to make use of the grafana/ui table component and am having trouble generating a table. I followed this guide for creating the grafana dataframe. One other post someone made suggested that the solution was in this buildData() function, but I am not sure how I would go about using that either or why it is needed.
I am trying to make use of the Table component within a larger panel plugin that I am building. Below is my attempt at generating a table using dummy data. Currently it builds a table with the correct headers and number of row/columns, but the cells are not populated with any of the data.
import { Table } from '@grafana/ui';
makeComponentWithData(width: number, height: number) {
let testStrings: string[] = ['wdwdq', 'wwwrr'];
let testNums: number[] = [6, 6];
const data = toDataFrame({
fields: [
{ name: 'strings', type: FieldType.string, values: testStrings },
{ name: 'nums', type: FieldType.number, values: testNums },
if (data === undefined || data.length === 0) {
return <p style={{ textAlign: 'center' }}> No Data </p>;
} else {
return <Table data={data} width={width * 0.9} height={height * 0.9} resizable={true} />;
