I want to show a Grafana dashboard in an iFrame of jarVIS (ioBroker surface). However I cannot log me in there and I’m trapped in a loop there. Now I’m wondering if I can create a link with an API key to directly open up the dashboard. Is this possible? I was able to create an API key, but did not find any information on the structure of the URL and settings to call a dashboard.
Search first - see if someone else has already asked and received an answer to your question. Searching might be how you found the forum in the first place.
Otherwise there will be many topics about the same problem. What is better? Multiple topics with low quality (e. g. no answer, answer which will be can increase security risk,…) or single topic with proper answer?
