Hi Grafana Community,
I’m trying to integrate grafana in our application where we run multiple apps inside iframes. So let’s say we have a master iframe which contains all the navigation links to available apps and a nested iframe of active application. The grafana will also be available as an app inside a nested iframe.
The use-case I’m trying to support here is that on click of a data (inside any native grafana panel like table, chart, etc.), the user will be switched to another application with the relevant data.
I can’t use actual navigation here as it will transform the nested iframe of Grafana to another app entirely. I can talk to master iframe with data and it can make the required app iframe active but in order to do that, I’ll have to either execute a custom javascript code or trigger a custom event. Unfortunately, both of these are not supported by data-links of native grafana panels.
Can someone suggest any strategy or a way to acheive this.
I also, tried to add click event listener and was able to get to the html ellement as well but there I was not able to access any required data that Grafana provide with data-link like cell, row, etc.
Note: Version I’m using is Grafana v11.5.2
