502 Bad gateway K6 studio (self-signed certificate in certificate chain
Hi everyone,
I just started with K6-studio (version 1.0.2), installed on Windows 10.
Recording an app on the internet looks fine but trying an internal resulting in
502 bad gateway (certificate verify failed: self-signed ceriticate in certificate chain.
If I look at the response headers
Could this error due to the company proxy? I use K6 studio in regular mode.
Any idea how to solve this?
Kind regards
Patrick Graas
Hi @pgmhjp,
If your network is passing through a proxy, you will need to configure k6 Studio to use those same proxy settings so a connection can be established. You can see your proxy settings on Windows by going to “Settings” > “Network & Internet” > “Proxy”.
In k6 Studio, you will need to change your Proxy mode to upstream and point it to the proxy your network is using. In some cases, you may also be required to attach a certificate so a trusted connection can be established.
Let us know if you need additional assistance.
Hi Cristiano,
Thanks for your quick response. I tried with your suggestion but still the same result.
See below error’s. If you need more let me know.
Kind regards Patrick
k6 studio log
[2025-04-08 11:33:51.351] [error] [11:27:44.319] Unhandled error in task.
[2025-04-08 11:33:51.353] [error] Traceback (most recent call last):
[2025-04-08 11:33:51.354] [error] File “asyncio\events.py”, line 80, in _run
[2025-04-08 11:33:51.355] [error] File “asyncio\proactor_events.py”, line 162, in _call_connection_lost
[2025-04-08 11:33:51.356] [error] ConnectionResetError: [WinError 10054] De externe host heeft een verbinding verbroken
Hi Cristiano,
It looks like its working. The certificate with the chain did the trick.
Thanks again
Does disabling “certificate verification” in K6 (using insecureSkipTLSVerify: true) allow the recording to proceed?
Hi, I’m not sure I understood the question because you don’t have direct access to k6 itself in this application :thinking:
If you want to enable the mentioned behaviour you should do it via settings:
