Hello! Can someone help please? Not sure how to locate the problem
Grafana CLI version 7.5.10 -
Reduce amount of errors in logs -
I’m not sure what to do -
What happened?
When my dashboard is opened in browser I’m having a massive amount of 404 errors in logs - 34 input every 5 sec (the dashboard refresh rate).
My dashboard is working great nevertheless -
I expect no errors
I have about 100 panels with the Prometheus metrics query like
app_status_rabbit_value{host="$host"}
or app_status_rabbit_value{host="$host"}+app_status_value{host="$host"}
etc -
Sep 6 17:47:12 hostname grafana-hostname[2854527]: t=2021-09-06T17:47:12+0300 lvl=info msg="Request Completed" logger=context userId
=1 orgId=1 uname=admin method=GET path=/api/datasources/proxy/1/api/v1/query_exemplars status=404 remote_addr=1.3.4.5 time_ms=0 s
ize=19 referer="https://dashboard.path/LFDCEWFWE/dashboardname?orgId=1&refresh=5s"
- Did you follow any online instructions? If so, what is the URL?
No
