404 error while developing custom datasource plugin
I am developing a datasource plugin but I am running into a rather strange issue. Below is some context to our problem.
The first issue I encountered was knowing how to include npm modules in the browser so grafana can use them (node-rest-client-promise, for example). This GitHub issue: https://github.com/grafana/simple-json-datasource/issues/19 says to copy the modules into the src folder (it seems like grafana does not look in the node_modules directory) in order to make it accessible to grafana via the browser.
This led to another issue with require statements not being understood by the browser so I am using webpack to bundle the modules and make such statements understandable to the browser.
However, in doing this, webpack does not understand the path ‘app/plugins/sdk’ in the queryCtrl for importing the queryCtrl class. I came across the following Stack Overflow post:
https://stackoverflow.com/questions/47624327/typescript-import-paths.
Which suggests using grafana-sdk-mocks to fix this path issue. So I copied over the module into the src folder but it doesn’t show up in the browser and it seems that something is appending a .js extension to the path.
Error Message when attempting to select our custom datasource plugin:
Failed to load resource: the server responded with a status of 404 (Not Found) row_ctrl.ts:73 Plugin component error Error: Fetch error: 404 Not Found Instantiating http://www.community.grafana.com/public/plugins/name-of-plugin/libs/grafana-sdk-mocks/app/plugins/sdk.ts.js. <= here is the appended .js
Loading http://www.community.grafana.com/public/plugins/name-of-plugin/query_ctrl.js Loading plugins/name-of-plugin-datasource/module at index.js:20
The grafana documentation is not very clear as to how grafana looks for imported modules nor how it resolves the ‘app/plugins/sdk’ path since it is nowhere to be found locally.
Technologies we are using:
Grunt => Used to copy from the src/ directory to the dist/ directory and handle babel transpilation
Babel => Used to transpile from ES6 to ES5 standards
Webpack => Used to bundle node modules and make them accessible to grafana via the browser
Our pipeline:
$ webpack
$ grunt && brew services restart grafana
Grafana was installed using these steps:
$ brew update
$ brew install grafana
$ brew tap homebrew/services
$ brew services start grafana
Any help would be greatly appreciated!
The advice about copying third party modules, in general, only applies to libraries which are otherwise not part of Grafana. The intention of grafana-sdk-mocks is to be a ‘stand-in’ interface that provides enough interface information for TypeScript to compile, and then the real modules will be supplied by the environment that Grafana loads the plugin into.
TLDR: grafana mocks and anything in node_modules/@types should be left in the node_modules folder, not moved into a lib folder.
