401 final error sending batch server returned HTTP status 401 Unauthorized (401)
Anybody familiar with this error?
I guess I am not replacing a value somewhere, but I can’t find the correct item to replace.
Nov 26 23:50:45 raspberry grafana-agent[2862]: ts=2023-11-26T22:50:45.231201431Z caller=client.go:430 level=error component=logs logs_config=integrations component=client host=logs-prod-012.grafana.net msg=“final error sending batch” status=401 tenant= error=“server returned HTTP status 401 Unauthorized (401): {"status":"error","error":"authentication error: invalid token"}”
I try to install the Grafana agent on a raspberry pi version 3b
  1. Install Grafana Agent : test ok
  2. Make configuration selections
Choose your OS
Select your OS
Debian - based
Architecture
Arm64
  1. Prepare your agent configuration file
yaml file:
integrations:
  prometheus_remote_write:
  - basic_auth:
      password: xxx
      username: 123456
    url: https://prometheus-prod-24-prod-eu-west-2.grafana.net/api/prom/push
  agent:
    enabled: true
    relabel_configs:
    - action: replace
      source_labels:
      - agent_hostname
      target_label: instance
    - action: replace
      target_label: job
    metric_relabel_configs:
    - action: keep
      regex: (prometheus_target_.*|prometheus_sd_discovered_targets|agent_build.*|agent_wal_samples_appended_total|process_start_time_seconds)
      source_labels:
      - __name__
  node_exporter:
    enabled: true
    relabel_configs:
    - replacement: 'raspberrypi3'
    - replacement: integrations/raspberrypi-node
      target_label: job
    - action: keep
      regex: node_cpu_seconds_total|node_disk_io_time_seconds_total|node_disk_io_time_weighted_seconds_total|node_disk_read_bytes_total|node_disk_written_bytes_total|node_filesystem_avail_bytes|node_filesystem_files|node_filesystem_files_free|node_filesystem_readonly|node_filesystem_size_bytes|node_hwmon_temp_celsius|node_load1|node_load15|node_load5|node_memory_Buffers_bytes|node_memory_Cached_bytes|node_memory_MemAvailable_bytes|node_memory_MemFree_bytes|node_memory_MemTotal_bytes|node_memory_Slab_bytes|node_network_receive_bytes_total|node_network_receive_drop_total|node_network_receive_errs_total|node_network_receive_packets_total|node_network_transmit_bytes_total|node_network_transmit_drop_total|node_network_transmit_errs_total|node_network_transmit_packets_total|node_uname_info|node_vmstat_pgmajfault
      source_labels:
      - __name__
logs:
  configs:
  - clients:
    - basic_auth:
        password: xxxx
        username: 745xxx (=different user name)
      url: https://logs-prod-012.grafana.net/loki/api/v1/push
    positions:
      filename: /tmp/positions.yaml
    scrape_configs:
    - job_name: integrations/node_exporter_journal_scrape
      journal:
        max_age: 24h
        labels:
          instance: 'raspberrypi3'
          job: integrations/raspberrypi-node
      relabel_configs:
      - source_labels: ['__journal__systemd_unit']
        target_label: 'unit'
      - source_labels: ['__journal__boot_id']
        target_label: 'boot_id'
      - source_labels: ['__journal__transport']
        target_label: 'transport'
      - source_labels: ['__journal_priority_keyword']
        target_label: 'level'
    - job_name: integrations/node_exporter_direct_scrape
      static_configs:
      - targets:
        - localhost
        labels:
          __path__: /var/log/{syslog,messages,*.log}
metrics:
  configs:
  - name: integrations
    remote_write:
    - basic_auth:
        password: xxx
        username: 129xxxx
    scrape_configs:
  global:
    scrape_interval: 60s
Any ideas/suggestions?
Have you tested the username / password on your Loki endpoint via the API?
Thanks for the tip, @tonyswumac .
I didn’t, but I’m trying now.
Can I use Postman?
POST https://logs-prod-012.grafana.net/loki/api/v1/push
Authorisation : Bearer Token = token ID in my Access Policy on Grafana Cloud
returns 401 Unauthorized
POST https://prometheus-prod-24-prod-eu-west-2.grafana.net/api/prom/push
Authorisation : Basic Auth with username & pwd in Yaml file (generated by Grafana, looks encrypted)
FYI: I also added my public IP address to my access policy in Grafana cloud, no change
I’d double check the username / password you are using for Loki then and make sure they are correct.
Couldn’t find the right values to use.
So I removed the grafana service, did an update of the system, even deleted the grafana token on the cloud, and reinstallled everything.
I had to manually create a /etc/grafana-agent.yaml (error: invalid permissions)
now it works fine
No idea what was going wrong, but it works now.
