I am not able to figure out how to create a three node monolithic cluster with GCS as object storage. I am not able to see my data in the bucket. not sure what I am doing wrong.
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9096
storage_config:
boltdb_shipper:
active_index_directory: /loki/boltdb-shipper-active
cache_location: /loki/boltdb-shipper-cache
cache_ttl: 24h # Can be increased for faster performance over longer query periods, uses more disk space
shared_store: gcs
gcs:
bucket_name: bucket-loki
common:
path_prefix: /opt/loki
storage:
gcs:
replication_factor: 3
ring:
kvstore:
store: memberlist
query_range:
results_cache:
cache:
embedded_cache:
enabled: true
max_size_mb: 100
schema_config:
configs:
store: boltdb-shipper
object_store: gcs
schema: v11
index:
prefix: index_
period: 24h
memberlist:
join_members:
- loki11001:7946
- loki11002:7946
- loki11003:7946
