Hi everyone,
We have a kubernetes cluster on GKE, we have deploy Grafana Loki + Promtail to collect all the logs of our containers. We have also configured grafana loki to store the logs (chunks) into a GCS bucket.
Now my question is about the retention period. If I did not make a mistake, with the configuration below we have configured a retention period of 24h
auth_enabled: false
chunk_store_config:
max_look_back_period: 0s
compactor:
shared_store: filesystem
working_directory: /data/loki/boltdb-shipper-compactor
ingester:
chunk_block_size: 262144
chunk_idle_period: 3m
chunk_retain_period: 1m
lifecycler:
ring:
kvstore:
store: inmemory
replication_factor: 1
max_transfer_retries: 0
limits_config:
enforce_metric_name: false
reject_old_samples: true
schema_config:
configs:
store: boltdb-shipper
object_store: gcs
schema: v11
index:
prefix: index_
period: 24h
server:
http_listen_port: 3100
storage_config:
boltdb_shipper:
active_index_directory: /data/loki/boltdb-shipper-active
cache_location: /data/loki/boltdb-shipper-cache
cache_ttl: 24h
shared_store: gcs
gcs:
bucket_name: k8s-monitoring-loki
table_manager:
retention_deletes_enabled: true
retention_period: 24h
But when I check now the content of my GCS bucket nothing is delete. Is this normal?
Thanks you for your help.
