grafana v8.5.13
elastic 8.9.1 - What are you trying to achieve?
separate data per environments
Choose environment which I want from combo box - What happened?
metrics are sum up. I want divide metrics per enviroment - What did you expect to happen?
I have one elasticsearch datasource → logging. I sent to this instance metrics from prod, and staging elasticsearch instance.
How is the data differentiated in elastic?
