X axis as integer
Hello all!
I would like to show some points on a graph… The problem is, that what I put in as X value is seen as string, so if I have 3 points on my x axis, for example 1 , 2 , 5, it will print them out as 1, 2, 5 with its correspondig values. what I would need is that it treats the X values as integers, so it will print 1,2,3,4,5 filling in the gaps with simply no value…
Can this be done?
Thank you!
Sharky
It should work without effort, as in this screenshot :
Can you share your use case.
Good Luck
Hi, thank you for your answer… can you try it with numerical values on the X axis instead of time?
example: (x, y)
1,10
2,30
3,14
5,17
7,20
Thank you
Maybe you have a problem with the decimal value
So adapt the unit and decimal (for your case 2). and test
Hope it helps.
Good Luck
