I’m starting to use WorldMap, but I do not understand very well, someone already uses it and could give me a hand.
I want to put some cities where I have servers and monitor if this UP or DOWN, with positions in the Map.
Any material that might indicate?
it depends on what datasource you are using. I recommend you to search worldmap in community. you can find a lot of topics which can help you
