We use shared crosshairs a lot to help match up state changes in our data. These work great on the Graph panel. I am experimenting with the timeseries panel (primarily for Y axis value mapping!) and noticed that the shared crosshair isn’t working.
Have I done something wrong or is it not supported? (and if not supported now, will it be in the future?).
Yes, for us it is also a very important topic, because we are using several panels beneath each other to compare the process data. Otherwise the new time series panels would be useless.
Annotations would be nice too on the Timeseries visualisation, similar to the Graph visualisation - Even better, allow multiple annotations to be visible at once, so we can highlight, label important events and then print the panel to share with others offline.
