I have created a dashboard according to attach pic and set value mapping for it .
I want if it finds error , errors , ERROR , Error in output shows check the log file and change color to red .
Now my output is showing :
Job “SYS”.“SYS_EXPORT_FULL_03” completed with 5 error(s) at Thu May 18 03:48:10 2023 elapsed 0 00:48:07
but another it is showing everything is ok . How can fix it ?
Would you please help me about it ?
is the mapping you currently have regex?
No . That is value . I am not using regex
it will require a regex value mapping. As you have it now, it thinks it is a literal string.
Does it your mean I have to change it such as attached pic ?
Can you please help me about it ?
Can anyone help me about it ?
Hi @alex23
Try this regex in your value mapping Regex field
[a-zA-Z](rror|RROR)
As it will look for strings:
error
Error
ERROR
You can also test it around using the online tool regex101
