Hi there !
I’m working with k6 to create stress test for an API. It’s working and i think i understand how it mainly works but i have something that i’m still not understanding.
So, i want to ramp up VUs like this :
scenarios: {
ramping: {
executor: 'ramping-vus',
startVUs: 0,
stages: [
{ duration: '10s', target: 10 },
{ duration: '20s', target: 10 },
{ duration: '10s', target: 20 },
{ duration: '20s', target: 20 },
{ duration: '10s', target: 30 },
{ duration: '20s', target: 30 },
{ duration: '10s', target: 40 },
{ duration: '20s', target: 40 },
{ duration: '10s', target: 50 },
{ duration: '20s', target: 50 },
{ duration: '30s', target: 0 }
And here is the result :
As you can see, my users are ramping up over the time and the response time is also increasing.
So my first question is : Why is the request rate still at the same rate when i’m increasing VUs ?
In docs, i only found this : Ramping VUs
It says that no matter of VUs, it will send as much http requests as it can. Am i right ?
If it is, here is my second question : Why is it better to do this for a stress test instead of increasing req/s with VUs increasing ?
Thanks for your responses
