6.7.4 -
Use the diff() function for alerting -
Eval montonic increasing counter every 1m for 5m. Evaluate points from (1h, now). Get the diff and check if there has been any change. IE, diff() > 0. -
What happened?
diff() gets negative values when I know it’s not appropriate -
When I test my alert, I see that the points do not come back in sorted time order. This seems like a problem. As I can’t find any docs on diff(), I checked the code (grafana/reducer.go at main · grafana/grafana · GitHub). It does seem to be doing what I expect. IE query(t1) - query(t0), except t1 and t0 here are not as expected. The test data looks like this -
0:Array[15172,1626882120]
1:Array[15192,1626882900]
2:Array[15257,1626884820]
3:Array[15159,1626881460]
4:Array[15170,1626881940]
Clearly Point 3 and 4 occurred before 0 and 1?
What is going on here?
