Where does Grafana save its configuration?
I see in
make all configuration changes in either
custom.iniorgrafana.ini.
- Default configuration from
$WORKING_DIR/conf/defaults.ini- Custom configuration from
$WORKING_DIR/conf/custom.ini
However, after I changed the Organization from the default “Main Org.” and save, I see no changes for any file under my Grafana installation:
C:\Program Files\GrafanaLabs\grafana\conf
So, where is this $WORKING_DIR/conf/ under Windows?
Also, I’ve created several users, where do those users configuration saved?
Basically I want to duplicate to another Grafana instance, without going through all the manual configurations that I had done before. Is that possible?
Thanks
