When Support ClickHouse Alert?
Grafana only supports alerting for core data source plugins that runs in the grafana backend. Clickhouse runs in the Grafana front-end why right now alerting can’t be supported. We want to implement support for backend plugins and when that’s finished anyone should be able to implement a data source plugin with support for alerting.
Marcus
How long is expected?
You can check our roadmap. Hopefully grafana v5.2, but maybe v5.3.
ok, thank you very much!
Is it done already, somebody knows?
I define a alert rule with clickhouse datasource,and when i click ‘Test rule’ button,i got the following error message:tsdb.HandleRequest() error Could not find executor for data source type: vertamedia-clickhouse-datasource.
Any body know why this happends?Grafana ver(Grafana v7.1.5 (9893b8c53d)
) and clickhouse version(20.4.5.36).
