When editing the panel, the variables in the query are replaced with fixed values
    Ubuntu Grafana v11.3.1 plugin: apache-iotdb-datasource-1.0.1
    I want to use variable to query different data.
    I add a varibale called sen.
and in panel, I use this query:
  • What happened?
    It works. but when I click edit :
    the varible is replaced by a fixed valve, like this:
    after I click edit, the varible is still in the query .
    It’s caued by grafana or iotDB plugin? thanks !
    no
    no
  • no
